Assessing my house for further insulation / weatherisation ?
swayzak
by swayzak » Wed Nov 26, 2008 3:00 pm
hi
I recently moved into a 1963 detached house with the first floor in the roof e.g. kind a chalet style with dormer windows.
This was in the summer.
It has (old) cavity wall insulation & I had Mark Group insulate the loft for me.
However, now it's winter I've noticed how cold it can become, especially upstairs.
I've put this down to the style of house ie. the upstairs rooms are not surrounded by brick but are really partially under the roof space.
I recently located very cold drafts coming through my bedroom units - took the draws out and noticed raw floorboards (with gaps) under the bottom draws. This was where most of the drafts were coming from, so I've covered them with rubber backed carpet & this has helped.
I'm now beginning to realise that previous occupants' modifications were maybe not to the highest standards :roll:
But it is still not that warm upstairs.
What I would really like is for a "weatherisation" expert to come round and assess the whole place & suggest remedies.
Do such specialists exist ? I guess they would not just be insulation people but maybe have building / roofing expertise as well .. ?
Advice would be very much appreciated.
thanks
surveyor
by welsh brickie » Wed Nov 26, 2008 7:43 pm
what you need is a good architect.
But do some homework on insulation the house just needs an upgrade.
the architect will advise you on the lastest and most efficent way of insulating your home.
swayzak
Re: surveyor
by swayzak » Thu Nov 27, 2008 10:25 am
[quote="welsh brickie"]what you need is a good architect.
the architect will advise you on the lastest and most efficent way of insulating your home.[/quote]
thanks
Am I right in thinking that these "chalet" style first floors (if that's what they're called) are prone to cold (more than traditional houses) ?
Perry525
by Perry525 » Fri Nov 28, 2008 3:42 pm
Building in the sixties was very basic.
It was also before the first oil scare in the seventies.
It was only after the seventies that insulation first became an issue.
The chances are that hidden behind the plasterboard is nothing more than fresh air.
If you have access take a look.
The likelihood is that along with thousands of other homes, yours has little or no insulation.
Probably none of the plasterboard upstairs has any insulation behind it.
To do a decent job it probably should all be removed and properly insulated. By this I mean four inch thick polystyrene or similar between the woodwork with all holes carefully filled and a further one or two inches of polystyrene over the complete area to avoid the woodwork becoming the weak link and leaching the heat away.
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 8:44 am
It is currently Mon Nov 25, 2024 7:00 am
