describe how joints are finished after lead flashing has bee
petemelody
by petemelody » Wed Nov 26, 2008 6:45 pm
describe how joints are finished after lead flashing has been secured
Grandad
by Grandad » Fri Nov 28, 2008 4:09 pm
Traditionally bricklayers left a raked out joint around a chimney or roof/wall abutment where lead flashing was to be installed. This left a gap of about 10mm high, some 20 - 25mm deep, and the lead flashing was tucked into these joints and lead wedges hammered in on top of the flashing to hold it in place. After all this there remained a gap of 7 - 10mm to be pointed up or filled. So a strong mix of cement mortar was used and the joints pointed up and finished to match elsewhere.
These days it is common to cut into a normal mortar joint with an angle grinder and form a slot about 3mm high and 25mm deep. The flashing is then tucked in and wedged in place as before, but now there is only a small gap over the flashing to be filled. This can be done with a cartridge gun and a sealant made for this particular applicatin. It is widely available in most merchants.
Grandad.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:05 am
It is currently Mon Nov 25, 2024 7:58 pm
