Artexing
thedoctor
Artexing
by thedoctor » Tue May 30, 2006 4:32 pm
To post a question for a Diy Doctor tradesman or your fellow users, to answer please click on “New Topicâ€
skaty55
by skaty55 » Sun Mar 04, 2007 12:41 pm
I understand that asbestos was used in artex can you tell when was that stopped and how would I find out if the artex in my house contained asbestos?
thedoctor
by thedoctor » Sun Mar 04, 2007 9:47 pm
Artex contained asbestos up until 1980. It requires chemical analysis to find out if your artex contains asbestos and if you are in any double, please assume it does. If you are asking this question because you want to remove some, please see the project on the website called Artex Removal. It can be done safely this way but do not attempt to sand it or scrape it off dry.
thedoctor
by thedoctor » Fri Mar 16, 2007 1:40 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
Chivs
Artex Containg Asbestos Fibres
by Chivs » Tue Apr 03, 2007 11:31 am
X-Tex Textured Coatings Remover is probably the safest way to remove artex contining asbestos fibres. Do not waste your time getting it tested as it will cost a small fortune for someone to come and do the test. I always feel that you should just assume that if it is pre 1985 that it will contain asbestos.
This product will encapsulate the artex and keep it wet at all times and prevent any dust which is the problem. You can quite safely remove artex as long as it stays wet or damp. People say that steaming will keep it wet, but it will soon dry out once it is on the floor and then will create a dust, and the heat burns like hell.
Skimming over or re-boarding used to be an option years ago but I am sure these days you would not be able to sell your home if this is detected and would have to remove all of the artex before hand. See the artex removal project in the projects section.
It is currently Sun Nov 24, 2024 12:20 pm
