Single Pump for Hot Water
scotzman
by scotzman » Thu Nov 27, 2008 5:57 pm
Hi, is there any way I can boost the whole hot water feed. My pressure isn't great at the moment and I want to install a new shower. My cold water runs off the mains, but is there a pump I could use on the hot water only?
The normal shower pump have both hot and cold inlet/outlet. Could I possibly use one of these without using the other?
Many Thanks
Dougie
matthewm1965
by matthewm1965 » Fri Nov 28, 2008 1:25 pm
Salamander do a range of single pumps.
Don't just use one side of a twin pump. It wont last long!
Matt
Perry525
by Perry525 » Fri Nov 28, 2008 3:08 pm
If you fit a booster pump you must have a water meter.
plumbbob
by plumbbob » Fri Nov 28, 2008 7:21 pm
You can't fit a mixer shower by using mains water for the cold and water from a cylinder and header tank for the hot. Both feeds must be at equal pressure. If you don't have a combi, then the hot will come from the cylinder and the cold should come from the header tank and then fit a twin impeller pump.
Download any mixer shower installation instructions for further advice.
It is currently Tue Jan 28, 2025 11:50 pm
