Reversing the direction of fall
Tommy
by Tommy » Sun May 13, 2007 8:45 pm
I have a concrete shed approx.10 ft. by 10 ft.,with a reinforced concrete roof approx.6 inches thick one end and 5 inches the other end to let the water run off.
I want to reverse the slope so that the water will run off the opposite end to what it is now.
Also I want to know what preperation I need to make it waterproof and also the mix.
bg
by bg » Tue May 15, 2007 7:00 am
To reverse the fall in concrete you would need to add a minimum of 75mm at the high end going up to 125mm at the other. This would be a huge weight but 75mm of concrete is the minimum suggested for construction water tightness. It would be better to fix timber firring pieces (Timbers cut to a lope) to the concrete and put ply decking on. The ply could then be covered in felt, fibreglass or rubber. See the flat roofingf project on the website via www.diydoctor.org.uk/projects.htm
It is currently Thu Nov 21, 2024 3:59 pm
