I want to replace my old thermostat with a Drayton Digistat 3. My old stat has two wire (red and a yellow) there is also an earth and an unused blue wire.
My Digistat has 3 terminals shown as C, Call and Sat (satisfied ?) How do I connect it please. I've tried lots of different combinations with the two wires but none seem to work properly. The nearest I've got is the stat calling for heat but then it won't switch the heating off. Should I use the blue wire as well ? Which ones should the red and yellow go in ?
