concrete slab
jonas
concrete slab
by jonas » Fri Dec 05, 2008 4:03 pm
I am in the process of laying a concrete slab in the courtyard of a property in central london it is approx 200 sq ft. It will lay on a clay base do I need to lay hard core or can I sand blind the clay, lay polythene then install insulation and steel then pour concrete? Can I cast a slab of this size in one go or would it need to be cast in several pieces?
Any help would be appreciated.
Jonas Cooper
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:01 am
It is currently Thu Jan 09, 2025 10:19 pm
