how do i fix a 47" LCD tv to very soft thermal breeze b
m7jgp
by m7jgp » Mon May 14, 2007 1:34 pm
Hi just had a house extension built, and would like to put a very large Lcd on the wall i am a little concerned as to what fastners to use, tv comes with a large wall bracket which has to be firmly attached to the wall which is dry lined on to very very soft thermal breeze blocks, what fastners do i use ?
thedoctor
by thedoctor » Wed May 16, 2007 3:41 pm
If there is a gap between the back of the plasterboard and the blocks you really need to cut out a section of the plasterboard and fix timber to the wall using 3inch number 8 screws and red wall plugs (see our fixing to masonry project). The TV brackets can then be fixed to the timbers. Sometimes its as easy to cut out a section of board and fix a timber, say 9 inch x 1 inch to the wall to a length = to the distance between the brackets. The brackets are then fixed to the timber and the timber is decorated to match the wall. You may find that a timber 1.25 or 1.5 inches thick is required for the face of the timber to be flush with the face of the plasterboard when its fixed.
It is currently Thu Dec 12, 2024 3:54 pm
