Conservatory wiring
Philphog
Conservatory wiring
by Philphog » Mon Dec 08, 2008 10:18 am
I plan to extend living room ring main to include new conservatory where there will be three 2 gang sockets. I also plan to install two wall lights fed from new 13 amp socket through a switched SP 5 amp fused connection unit. 2.5mm wire to FCU and 1.5mm from FCU to lights. I have a couple of questions :
1. Can I wire direct from socket to FCU and then to lights and use the switched FCU as the light switch.
2. Can I run ring main cable along bottom of wall at floor level, secured with cable clips or do I need to use conduit.
by sparx » Mon Dec 08, 2008 6:24 pm
Hi, 1) yes!
2) you could but it would look cr^p!
why not get some small skirting trunking, quite inexpensive from various 'sheds', this is considered a 'safe zone' as long as you go vertically up from trunking to outlets.
regards Sparx
Philphog
by Philphog » Tue Dec 09, 2008 1:09 pm
Thanks Sparx for your response.
Regarding 2) I should have said cable would be hidden from view in void between plasterboard and brick however I'll follow your advice and use trunking.
Regards
Philphog
It is currently Sun Jan 19, 2025 7:48 pm
