switch wiring
ramongunners
switch wiring
by ramongunners » Fri Dec 12, 2008 12:08 am
trying to connect a switch to pelmet lighting where does the live neutral and earth connect to the switch has a common one way and two way thanks
by stoneyboy » Sat Dec 13, 2008 10:32 am
ramongunners,
If you are not sure about what to do I would suggest you get someone in to give you a bit of advice.
The neutral and earth go straight through the switch box and are not connected to the switch. The live is fed into either L1 or L2 and the common is connected to the live wire to the lights.
by ericmark » Sat Dec 13, 2008 5:45 pm
At the bottom of my web page http://www.ericpalmer.fsnet.co.uk/Lighting.html I have added a little on the light switch I hope this helps.
Eric
It is currently Sun Jan 19, 2025 7:55 pm
