showers
broughts
showers
by broughts » Fri Dec 12, 2008 7:51 pm
HI.When buying a shower unit what does KW mean? for example 8.5kw. thanks
C23kW
Re: showers
by C23kW » Sat Dec 13, 2008 1:23 pm
its mean the power output the shower. this wll be electrically wired and if you had an electric shower before and the Kw was less then buying an 8.5 Kw shower, might mean changing the wiring to the shower from the Db (consumer unit). If firstly installing then the manufacturers instructions will help you with wire sizes etc.
plumbbob
by plumbbob » Sat Dec 13, 2008 1:26 pm
Kw equals kilowatt hours. Basically, the bigger the KW, the larger the element and consequently the more water can be heated at once so the better the shower.
Showers range from about 7.0 kw up to 10.5 kw with 8.5 being the most common.
A 10 kw shower would use 10 units of electricity in one hour, or 5 units in half an hour etc.
It is currently Wed Jan 29, 2025 12:02 am
