Problem with Bosch Fan Assisted Oven
7 posts   •   Page 1 of 1
PEGB1962
by PEGB1962 » Sat Dec 13, 2008 10:52 am
Help Please
I have a Bosch fan assisted electric oven (Model HBN4305.0B)
which has suddenly stopped working. No fan, grill, oven....nothing.
Any ideas on where to start looking to identifying the problem would be gratefully welcome.
PB
by stoneyboy » Sat Dec 13, 2008 3:12 pm
PEGB1962,
Your main consumer unit/fuseboard should be the first thing to check. If this is OK has the isolating switch to the oven been turned off.
plumbbob
by plumbbob » Sat Dec 13, 2008 10:59 pm
The oven is probably plugged in to a 13 amp socket in the back of a nearby cupboard. Have you checked the plug's fuse?
PEGB1962
by PEGB1962 » Mon Dec 15, 2008 4:56 pm
Apologies I should have said.
There is power to the oven, the clock's lit
Thanks again
PB
PEGB1962
by PEGB1962 » Wed Dec 17, 2008 6:35 pm
Bosch have advised that it could be either the element, stat or function switch.
Could anyone please tell me where these are located within the appliance and how I might test them
PB
plumbbob
by plumbbob » Thu Dec 18, 2008 7:12 pm
No one here will be able to answer you question exactly because there are so many different appliances about and even repair people won't know until the back is off.
Firstly, I would cross off the element as the cause because the fan isn't running and both elements would not be faulty together. I would also discount the thermostat for the same reason. This leaves the function switch on the front panel (the knob you use to turn the oven on).
Before you dismantle that, I would remove the cover where the power enters the oven. The cover is usually fixed with two screws and behind it is the connector block. I would examine this for any electrical damage.
Ensure the supply is disconnected before removing the cover.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 9:37 am
It is currently Thu Oct 31, 2024 7:35 pm
