Leaking double glazing
philbasford
by philbasford » Sat Dec 13, 2008 4:42 pm
one of my window leaks when it rains, its double glazed, a small damp patch appears at the bottom corner(but only one corner of the window), i thought i had solved the problem, but it seems to be backed, an just wondering what the next step might be.
Ie replaced the sealent, but today the patch of damp was 3 times the size of what it used to be and am now getting rather concerned
Any help would be appreciated!
Ps.
It only gets damp on the inside when the rain is heavy for a decent period of time.
by stoneyboy » Sun Dec 14, 2008 10:21 am
philbasford,
I assume you are saying that the water is coming in around the glass unit.
How are the DGUs sealed into their frames? eg is it a bead of putty, is there a full bead of bevelled putty around the window, is the DGU set in a rubber seal, what sort of frames are they?
tim reeve
by tim reeve » Fri Jan 09, 2009 9:25 pm
just a guess.Because i have seen this before,you need to take the glass out, the glazing packer is covering drainage hole on one side.hope this helps .email if you want more info.
TheDoctor5
by TheDoctor5 » Mon Jan 26, 2009 10:42 am
It is currently Mon Nov 25, 2024 12:02 am
