changing an electric oven
Mike_S
by Mike_S » Sun Dec 14, 2008 7:58 pm
I have bought a 2nd hand oven as a stop gap as my old one has just died. The old oven was powered by a standard plug but the new oven looks like it has been previously fitted into a seperate cooker switch on a wall.
My kitchen doesnt have this type of fitting so would the oven be able to have a plug attached and put into a standard socket or do I need an electrician to fit a dedicated cooker switch?
If so, how much us this likely to cost?
Thanks for any info
by stoneyboy » Mon Dec 15, 2008 11:15 am
Mike_S
You should have a cooker switch on the wall - the cost will depend on whether a new circuit will have to be provided.
plumbbob
by plumbbob » Tue Dec 16, 2008 11:55 pm
You do mean oven not cooker? If it is a cooker with electric hob, it will need it's own dedicated supply as the hob part uses lots of kw. Double ovens often need their special supply from a cooker switch too, but not always. Single ovens can normally be run from a standard 13 amp plug.
If you open the front door of the oven, around the front edge (not the door) is usually a white sticker with the kw rating. A 13 amp plug will supply up to 3.0 kw or 3000wats.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 9:38 am
It is currently Thu Dec 26, 2024 4:42 pm
