by AdamsHeating »
Tue Dec 16, 2008 8:24 pm
First of all, thank you!
The system:
full gravity fed, pumped y-plan system, midposition 3 port valve (3PV), simple potterton 15kw regular boiler with all the usual gubbings (room stat, time clock, cylinder stat) in with the cylinder. 3 story town house, 3 rads top (beds), 5 rads middle (living), 3 rads ground (kitchen). 11 rads in total... all on 10mm pushfit that is on display and i'd image 15/22mm lurking under the floorboards as per.
When in mid position water is scorching and the last two radiators on the loop do not get hot. 3PV is definitely working as the call for heat from both CH and HW is always satified, both together and individually.
I balanced the rads (prev plumber left lockshield fully open... i think we've discussed that before!) and when in CH mode only, the rads heat up fine, it's only when the CH and HW are calling together, the two rads in kitchen go cool/cold.. heating still works for the rest of the house and the hot water is up at about 75/80 degrees at the tap, so my thermometer tells me.
Pump is set to 3 and is working fine, no sludge in system as it is relatively new.
So my question is, any ideas why when in mid position those last two rads go cold? Do you think there could be a problem with the valve itself when in mid setting?
Cheers Gentlemen.
