PIR lighting loads
raytay
PIR lighting loads
by raytay » Thu Dec 18, 2008 2:07 pm
Can anyone advise why the manufacturer's fitting instruction for a domestic PIR sensor recommends a minimum time setting of 3 mins when using compact flourescent energy saving lamps as the load.
The PIR in question is an Osprey Standalone Movement Sensor bought from B & Q.
by ericmark » Fri Dec 19, 2008 4:05 pm
it takes 2 to 3 mins for a discharge bulb to reach full brightness and it would really reduce it's life if switched of before fully on regularly.
Eric
raytay
by raytay » Sat Dec 20, 2008 10:10 am
Thanks for your reply Eric. The answer you gave was in line with my own thinking but I wondered if there might also be an issue with 'back emf pulses' seeing as the load has an inductive choke which might affect the relay contacts adversely.
I contacted the manufacturer. The person I spoke to insisted that it was the PIR detctor that would be damaged and that if the time setting was only seconds it would soon blow the PIR sensor. They did not enlarge on this answer and I am somewhat dubious.
I have in any case set the timer to approx 3 mins.
by ericmark » Sat Dec 20, 2008 11:11 pm
Without doing some reverse engineering I have no idea the internal switching mechanism used. It could be solid state and there may be a heat problem if switched too quickly.
Eric
It is currently Sun Jan 19, 2025 7:53 pm
