External rendering over cement fibre board??????
6 posts   •   Page 1 of 1
Kenco
by Kenco » Mon Dec 22, 2008 7:03 pm
Hi there
Brand new to this forum so a big hello to all out there.
I am in the proccess of building a house in the south of France, the construction of which is rather unusual!! It being a light weight steel framed construction.
My problem being that I have used a fibre cement board (Marley Eternit Duripanel) as the outer skin of the house and I now wish to render it.
I have done a bit of research on this and it would seem that the recomendation is to go with one of the new type thin coat silicone/acrylic type systems.
Whilst I'm sure these systems are "the dogs whatsits!!" they are also prohibitevely expensive!!!
They consist of a base coat. scrim, primer, adhesive and finaly, top coat!!
As I'll be working of moveable scaff towers, the labour involved in moving these the 3 or 4 times to achieve the finish is in its self financially a big NO NO!!
In an ideal world, I would like a one coat spray on render that would be suitable for (and adhere to!) the fibre cement board.
Obviously I do not want the render to crack, so I would prefere a degree of flexibility in the finish render, being in the south of France the temperature can range from -8 to +38 degrees c. (though hopefully not on the same day!!)
Any and all suggestions would be greatfuul recieved (short of knocking it down and re-builing in brick!!)
Regards to all
Kenco.
by stoneyboy » Wed Dec 24, 2008 12:01 pm
Kenco,
The problem with this type of board is getting a secure bond to the board especially where it will be exposed. I suggest that the only way of using a normal cement screed is to first fix stainless laths over the outside of the boards and screed on this.
Kenco
by Kenco » Thu Dec 25, 2008 7:50 pm
Thanks for that, I was kinda hoping that there was some magical substance that could be "painted" on to the cement board in order to provide the neccessary key for the render, a bit like diluted PVA as you would paint onto interior plaster work in order to ensure good adhesion. Any comments??
Kenco
by stoneyboy » Sat Dec 27, 2008 10:59 am
Kenco,
Sealing the outside of these boards is a no no - they must be able to breath through the coating. How about using a micro-porous masonry paint, eg sandtex, I think this can be applied direct.
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 2:17 pm
Carl Rotheram
Cement board coverage
by Carl Rotheram » Tue May 05, 2009 10:22 pm
[quote="Kenco"]Thanks for that, I was kinda hoping that there was some magical substance that could be "painted" on to the cement board in order to provide the neccessary key for the render, a bit like diluted PVA as you would paint onto interior plaster work in order to ensure good adhesion. Any comments??
Kenco[/quote] :lol:
Hi Kenco
There are a few different finishes for this application. A acrylic render can be applied on to the board as long as it as been primed with the right primer. The joints need to be taped before hand.
Another product Renotex rollercoat spray apply or roller. Apply cenent based bagging coat first
It is currently Thu Dec 26, 2024 4:25 pm
