WOODEN FLOORING RISING
suzanne hughes
by suzanne hughes » Tue Dec 23, 2008 5:28 pm
OUR DOWNSTAIRS FLOOR IS CONCETE, THEN A LAYER OF PLY WOOD AND FINALLY WOODEN BLOCK FLOORING. THIS IS IN MY TWO DOWNSTAIRS ROOMS AND HALLWAY. I HAVE NOTICED IN THE TWO ROOMS THAT IN CERTAIN AREAS THE FLOOR IS RISING. THE HOUSE DOES SUFFER WITH CONDENSATION. COULD THIS BE THE REASON THAT THE FLOOR IS RAISING? COULD THE PLY BE ABSORBING THE MOISTURE AND THEN EXPANDING? THE PLY WAS SCREWED DOWN INTO THE CONCETE. IF WE PULLED UP THE FLOORING WE WOULN'T BE ABLE TO RELAY IT AGAIN. ANY ADVICE?
by stoneyboy » Wed Dec 24, 2008 10:49 am
suzanne hughes,
When the floor was laid an expansion gap of about 5mm should have been left on all side of the plywood. You have little choice but to relay the floor.
TheDoctor5
by TheDoctor5 » Mon Jan 26, 2009 10:11 am
J.G.F
Re: WOODEN FLOORING RISING
by J.G.F » Wed Feb 18, 2009 11:06 am
[quote="suzanne hughes"]OUR DOWNSTAIRS FLOOR IS CONCETE, THEN A LAYER OF PLY WOOD AND FINALLY WOODEN BLOCK FLOORING. THIS IS IN MY TWO DOWNSTAIRS ROOMS AND HALLWAY. I HAVE NOTICED IN THE TWO ROOMS THAT IN CERTAIN AREAS THE FLOOR IS RISING. THE HOUSE DOES SUFFER WITH CONDENSATION. COULD THIS BE THE REASON THAT THE FLOOR IS RAISING? COULD THE PLY BE ABSORBING THE MOISTURE AND THEN EXPANDING? THE PLY WAS SCREWED DOWN INTO THE CONCETE. IF WE PULLED UP THE FLOORING WE WOULN'T BE ABLE TO RELAY IT AGAIN. ANY ADVICE?[/quote]
Was there a Dpm placed under the ply and on top of the ply? if not then get in contact with your floor fitter and ask why!
It is currently Wed Nov 27, 2024 9:35 am
