Junction boxes
aria
Junction boxes
by aria » Mon May 14, 2007 10:30 pm
I've just completed adding a couple of extra sockets to the ring main. Job went well, simply cutting into existing ring main, adding junction box to branch off to new socket, then back to second junction box to link back into ring main. Extension probably no more than 5 meters or so to ring mian.
I've just realised that I didnt actually secure the junction boxes to anything. They are under floorboards, simply resting on the top of the ceiling below.
Since all the advice on this topic says to fix them, is this considered a problem? i.e. should I relift floorboards to secure either to the joist or a batton, or should they be ok as is?
Sorry if a daft question.
by sparx » Tue May 15, 2007 10:38 pm
Hi, not daft question at all!
the main reason for fixing to cross batten (noggin) is to lift cables clear of ceiling in case later someone tries to cut into ceiling ,say to fit the dreaded 'down lighters', so ideally cables should be clipped and jb's mounted in centre 1/3 of depth of joist so max distance from above & below,
Regards SPARX
aria
by aria » Wed May 16, 2007 10:44 pm
Many thanks Sparx.
It is currently Thu Dec 12, 2024 4:38 pm
