draughts in my new house
10 posts   •   Page 1 of 1
ed404
by ed404 » Fri Dec 26, 2008 4:59 pm
I have had a new house built and we get a lot of wind at the back where the kitchen is. I have lamenate flooring and lots of air bricks. Usually i get lots of draughts in this room but i recently covered the air bricks with a wall tile, not fixed. Is there a better solution as it seems crazy that planning made me put lots of insulation in my new house only to let the air bicks let the cold air in!!
Regards ed404
by stoneyboy » Sat Dec 27, 2008 11:46 am
ed404,
I assume you are referring to air bricks which ventilate the space under suspended floors. In this case you should not seal up the airbricks or you will get wet rot in the suspended floor.
Where are the draughts you refer to coming from?
Perry525
by Perry525 » Sun Dec 28, 2008 7:42 pm
Modern homes are built with as few holes and as insulation as possible to enable them to comply with the building regulations.
One wonders why the council would ask for air bricks?
Do you have an open fire?
Or a boiler that does not have a balanced flue?
A large gas burner of some description?
Or does someone like fresh air?
Do you have solid floors?
Most homes do these days, floor boards and open spaces including air bricks are impossible to keep warm.
Look forward to your reply.
Perry
ed404
Dear Stoneboy
by ed404 » Mon Dec 29, 2008 6:16 pm
most of the draughts are coming from where the giproc wall boards meet the hdm flooring
ed404
by ed404 » Mon Dec 29, 2008 6:18 pm
[quote="stoneyboy"]ed404,
end[/The draughts are coming from where the plasterboard meets the flooring]
ed404
by ed404 » Mon Dec 29, 2008 6:20 pm
[quote="Perry525"]Modern homes are built with as few holes and as insulation as possible to enable them to comply with the building regulations.
Perry[/yes I have an open fire, wooden flooring but no I do not want fresh air howling round the house!!quote]
by stoneyboy » Tue Dec 30, 2008 9:29 am
ed404,
From your reply it sounds like you have suspended floors, since your house is new insulation should have been fitted under the floorboards and around any perimeter walls. This should stop draughts from the wall/floor junction.
Without details of the type of construction of your house it is difficult to suggest a solution which will not give you problems elsewhere in the house.
I suggest your first action should be to contact the builder and or NHBC ( or whoever guaranteed the quality of construction)
Perry525
by Perry525 » Tue Dec 30, 2008 9:51 am
Solution is simple.
You run a four inch sewage pipe under the floor from the outside to as close to the fire as you can. (I terminated mine under the fire in a concrete box)
Fire then pulls cold air in from outside via the pipe. Room stays warm, no drafts, cheaper to run as you are not burning air you have already paid to heat. Air needs to move in room by convection only, at less than one foot per second.
Next, while the floor is up. Squeese four or five inch thick polystyrene sheets between the joists insulating the underneath of the floor boards - this will make an incredable difference to the comfort of your home. Make sure every hole is blocked.
Perry
the specialist
by the specialist » Fri Jan 09, 2009 7:12 pm
Re: Stoney boy's first comment. You meant dry rot not wet rot didn't you?
TheDoctor5
by TheDoctor5 » Wed Jan 21, 2009 2:11 pm
It is currently Thu Dec 26, 2024 4:07 pm
