Baxi Solo WM 50/4RS
bunts
Baxi Solo WM 50/4RS
by bunts » Wed Dec 31, 2008 12:03 am
Pilot lites but goes out when turn knob to next position. Thermostat trip switch has been reset but still does not resolve the problem. For information this started after I removed and replaced two radiators to clean them through and I completely drained the whole system to do this. Before trying to restart my boiler, the heating system was refilled and air bleeded from all radiators.
Steve the gas
by Steve the gas » Thu Jan 01, 2009 7:01 am
Hi Bunts,
You seem to be describing a permanent pilot that will not stay lit?
If so , the thermocouple has failed,approx £6 + fitting
Hth
bunts
Pilot not staying on
by bunts » Sat Jan 03, 2009 3:07 pm
Thanks for advice. Thermocouple changed but still not working. Engineer called and replaced the boiler thermostat which did the trick.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 12:34 pm
It is currently Thu Jan 30, 2025 5:46 pm
