ferroli combi boiler controls
jason h
by jason h » Thu Jan 01, 2009 4:13 pm
have got a ferroli boiler installed in my loft, if i need to put heating on constant during cold spell, have to go up to loft to alter setting on boiler, to constant and vice versa when switching it back. does anyone know if i can obtain a remote control? to adjust heating setting without needing to go up to loft???
Steve the gas
by Steve the gas » Fri Jan 02, 2009 7:10 am
Hi Jason,
Yes you can, check the ferolli website - they may do a remote wireless one but I'm not sure?
by htg engineer » Fri Jan 02, 2009 12:06 pm
Yes you will be able to fit a wireless programmer or programmer installed which is easily accessible.
But - your boiler should be easily accesible, loft boarded and lights. Loft ladder. So accessing the boiler should be easy not a hardship.
htg
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 12:32 pm
It is currently Thu Jan 30, 2025 6:10 pm
