Splitting up a garage
trezza
by trezza » Fri Jan 02, 2009 11:53 am
Hey, I want to split up my garage by basically just putting a wall in the middle. it's all brick with a corrugated iron roof and a bluestone floor. the garage has no door it is completely open to the backyard, what I want to do is nothing special and I could easily do it but the floor has an incline as you get further to the rear of the garage, the back area of the garage must have a flat floor as I will be doing some delicate work in there. All i want is an idea of how i can build this wall and flat floor as cheaply as possible.
thanks..
by stoneyboy » Sat Jan 03, 2009 10:24 am
trezza,
Use tapered joists with chipboard ontop for the floor, studwork with sheathing ply fitted to it for the walls.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:19 am
It is currently Sun Dec 22, 2024 7:09 pm
