by plumbbob »
Sat Jan 03, 2009 4:17 pm
IF you are using one of the proper drain tap points, it may be it is seized shut (it may unscrew but the rubber sticks to the seat. Watch out as it can come unstuck suddenly and you get black water everywhere.
If you are trying to drain a pressurised unvented system the upstairs radiator bleed valves must be open before the system will drain.
