WMS Key stuck in lock.....how can i remove it?
Marekuk
by Marekuk » Sat Jan 03, 2009 1:34 pm
I accidentally snapped the key on the front door. I have a spare key, so i would just like to get the other half of the key out of the door, and unfortunately it is still stuck in the door.
It is a WMS key on a lock, and i have no experience with locks, so do not know the first place to start. All i have tried at the moment is trying to push the key out with the spare key, but that didnt work.
I would greatly appreciate any tips that would allow me to avoid calling a locksmith out. (I can insert the other half of the key in from the inside and lock the door, but cannot insert a key from the outside)
Marekuk
by Marekuk » Sun Jan 04, 2009 10:15 am
I have heard that using a magnet to slightly extract the key and then removing it with tweezers works.
Can anyone comment on such a method (especially the bit with the magnet)?
mike lawrence
remove a broken key from lock
by mike lawrence » Mon Jan 05, 2009 7:09 pm
1st remove the cylinder from the door lock usually one screw under the door keep/nib mechanism u may have to twist the barrel then with the lock out, place in a vice with the rear of the lock uppermost then if u can see the tip of the broken key knock through the lock with a fine steel pin and small hammer if u cant see the back of the lock just tap the barrel on a wooden surface and u will force the key out enough so u can remove with a pair of tweezers.
TheDoctor5
by TheDoctor5 » Fri Jan 23, 2009 9:03 am
It is currently Thu Jan 09, 2025 6:18 pm
