Hanging radiators vertically
Rastanking
by Rastanking » Sat Jan 03, 2009 7:45 pm
Hello all,
I wonder if anyone can help me I want to hang a radiator vertically in my bathroom, however most of the brackets on the radiators allow the to be hung horizontally, do I require a vertically hanging radiator, if one exists, or do I need different brackets?
Any help anyone can give me would be appreciated, thanks in advance.
by stoneyboy » Sun Jan 04, 2009 2:32 pm
Rastanking,
Traditional radiators are only designed to be hung horizontally, the tallest narrowest you can get will be about 700x300mm.
If you want something taller you could fit a ladder towel warmer or you will have to go for a designer radiator - just search on line.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 12:35 pm
It is currently Mon Jul 01, 2024 6:33 am
