Tiling over cork
Northiam
Tiling over cork
by Northiam » Tue Jan 06, 2009 1:51 pm
I have a concrete floor with embedded underfloor heating that is covered with cork tiles. They are the original tiles and have been down 30 years. They are firm (ie not spongy) and very securely fixed. (I know because I tried to remove a couple and it look hours to remove just some of the adhesive.) I would like to lay some Amtico vinyl tiles using their HT adhesive (specially formulated for underfloor heating etc). I know that the 'correct' way is to remove the cork and re-screed the floor, but this would be very difficult (have to remove all furniture etc etc.). Does anyone have experience of laying over the existing cork?
by stoneyboy » Wed Jan 07, 2009 6:24 pm
Northiam,
There is a good chance that if you tile over the cork the amtico tiles will curl at the edges due to the polish/glue which has been used on the cork.
Strip and apply a self levelling compound will be the only sure way of success.
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:53 am
It is currently Thu Jan 09, 2025 2:41 am
