URGENT HELP NEEDED PENETRATING DAMP
gandy666
by gandy666 » Tue Jan 06, 2009 5:51 pm
Hi All
Hoping someone can help. We have a combi boiler in our 1st floor box bedroom cupboard that has a blow off pipe that leads to the outside wall.
This pipe has had a slow drip and has been dripping down the wall it seems for some time. This we think is a problem with the boiler and its top up mechanism (to top itself up when the pressure drops!)
In the temps that we have seen the water that has been on the wall has froze and now we have a frozen minni waterfall on the side of the house.
The wall inside is Very Cold and the paper is now coming off the wall - if you touch the wall it does in fact feel wet and damp.
We have someone coming to look at the boiler issue tomorrow but what will we do regards any lasting damage to the wall - do we need a proffesional to come nd look at it or is it a case of once the problem is removed the wall will dry out.
Claire and Damian Gandy
Manchester
by stoneyboy » Wed Jan 07, 2009 6:28 pm
gandy666,
Cure the leak - get the pipe extended so water drips clear of the wall and wait for better weather. Worry about the damp problem if it has not solved itself by the summer.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:03 am
It is currently Tue Dec 24, 2024 4:31 pm
