56mm waste pipe!!
Marks got problems again
56mm waste pipe!!
by Marks got problems again » Tue Jan 06, 2009 7:04 pm
Need to run 40mm waste pipe from bath, all drainage is internal and not easly accessable. The old waste pipe coming directly off the stack is 56mm, is there an adapter i can use to reduce down or another solution: im open to any suggestions. Cheers.......Mark[/b]
Steve the gas
by Steve the gas » Wed Jan 07, 2009 6:36 am
Yes you should be able to get adaptors. Take a small section with you to a good plumbers merchant - they will fix you up.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:22 pm
It is currently Mon Nov 25, 2024 10:13 pm
