Putting a cupboard around my gas meter
6 posts   •   Page 1 of 1
scoup
by scoup » Tue Jan 06, 2009 8:54 pm
I want to convert my integral garage into a room. The gas meter and electricity meter are located on the inside wall of the garage. I do not need any ventilation space around the electricity meter, but probably do around the gas meter.
Does anyone know the regulations on what amount of stand off etc or venting is required around the gas meter when building the cupboard over the meters?
Thanks.
Steve the gas
by Steve the gas » Wed Jan 07, 2009 6:28 am
Hi Scoup,
I think min ventilation is 5%.But you should not make it inaccessable, ie main valve must be accessable at all times, also preferable if the cover can be lifted off.
Hth
scoup
Cupboard around gas meter
by scoup » Wed Jan 07, 2009 9:12 pm
Thanks for this, can you expand on what you mean by 5%.
Steve the gas
by Steve the gas » Thu Jan 08, 2009 6:32 am
Off the shelf meter boxes have a min of 5% ventilation by cubic volume - I believe.
Check with Mitras a meterbox maker.
Hth
swidders
by swidders » Mon Jan 12, 2009 9:26 pm
You could also search online for the manufacturer's installation guide - don't know what make/model your boiler is but worcester gives guidelines.
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 11:19 am
It is currently Wed Jan 15, 2025 9:46 am
