Leaking thermostatic radaitor valve
p4t
by p4t » Wed Jan 07, 2009 12:05 am
hi,
a thermostatic valve on one om my raduiators has sprung a leak. I removed the head and noticed the water was dripping from around the pin. I tightened the nylon nut holding the pin in place which has seemed to stop the leak.
Is this good enough or would you recommend replacing the whole thing
many thanks
by stoneyboy » Wed Jan 07, 2009 6:47 pm
p4t,
Leave well alone and see if it leaks again.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:23 pm
It is currently Thu Feb 06, 2025 7:00 pm
