shower flow
steviem
shower flow
by steviem » Wed Jan 07, 2009 10:39 am
When I switch on my power shower I get a small flow of water then It stops,it can take more than five minutes for full flow to come on.Any Ideals welcome.
Also my bathroom sink hot water running hot and cold when hot I mean exceptionally hot.Any Ideals most welcome. [/b]
bobplum
by bobplum » Thu Jan 08, 2009 10:00 am
hi could be an airlock or the filters need cleaning on the shower
do you have a hot water tank if so check the stat temp,usually a little box on the side of the tank
steviem
by steviem » Thu Jan 15, 2009 8:41 am
Thank you for your reply hopefully this will solve the problem
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:40 pm
It is currently Fri Nov 22, 2024 10:07 pm
