rad on zero but heat coming out
kathedwards
by kathedwards » Wed Jan 07, 2009 11:44 am
Thanks Steve - When I said that rad was on zero I meant frost setting. If I put rad on 2 or 3 it still belts out even in the summer when it is hot and just the water is on. Is this a problem with the thermostat on that rad 'cos then i can get a plummer in.
I did not realise you have to leave a rad on all the time to protect the pump - does the frost setting count as on?
Steve the gas
by Steve the gas » Thu Jan 08, 2009 5:55 am
Yes, when TRV set on frost - it still allows a little flow.
It also sounds as if this rad is piped to the HW circuit as a het sync / bypass.
alandyman
by alandyman » Thu Jan 08, 2009 4:20 pm
also could be that the thermo valve is a one way type and fitted on the wrong end of the rad.
