Radiator Sizing
aaronmcclenaghan
Radiator Sizing
by aaronmcclenaghan » Wed Jan 07, 2009 12:03 pm
All of my radiators appear to be undersized in terms of BTU, Do I need to change all of the radiators???
uk_ducati
by uk_ducati » Wed Jan 07, 2009 8:16 pm
hi
if all the rooms are cold with them full on then yes. if the rooms are ok the rads are ok
paul
bobplum
by bobplum » Thu Jan 08, 2009 10:12 am
hi
ducati is quite right
but if this becomes an obsession you can do some research on the net regards radiater sizing or go to a supplier of central heating supplies and you can purchase some form of "matrix"device to work out the correct size
bob
plumbbob
by plumbbob » Thu Jan 08, 2009 5:27 pm
In fact this site in the projects section has a link to a radiator calculator.
What you need to be careful of is not to unbalance a system by fitting larger rads in some rooms and not others. If you do, some rooms may become very warm whilst others are cold.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:25 pm
It is currently Thu Feb 06, 2025 7:34 pm
