fitting new sink
rose
fitting new sink
by rose » Wed Jan 07, 2009 10:38 pm
hi guys/girls
am having a new sink and plumbing in wc downstairs.
does the pipe for the waste go underground or does it get fed thru the outside wall. by the way, the sink is being placed on an internal wall
thanks for any help
bobplum
by bobplum » Thu Jan 08, 2009 10:07 am
hi rose
im, guessing you are doing this work your self
i think this is one that needs to be answered by a plumber on site
bob
mattpark
by mattpark » Fri Jan 16, 2009 11:14 pm
Each situation varies, all depends on the positioning of the sinks waste pipe and the other waste pipes going away from your WC. As per other post it needs to be looked at to tell which route to take to join the existing wastes.
Generally in older houses wastes tended to go outside asap before going below ground, but in more modern houses they may well 'join up' and travel within the house and or go underground before leaving the premises.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:47 pm
It is currently Sat Nov 23, 2024 3:04 pm
