lead roof
8 posts   •   Page 1 of 1
rose
lead roof
by rose » Wed Jan 07, 2009 10:45 pm
i have extension being built and will have a part flat lead roof and tiles on the slopes.
does anyone know where i can buy reasonable priced lead from.
thanks
by stoneyboy » Thu Jan 08, 2009 6:02 pm
rose,
You could shop round your area and see what prices are like, try roofing contractors as well as builders merchants. Cheap lead is generally not a good idea - it has blow holes in it and the edge is not cut straight.
rose
by rose » Mon Jan 12, 2009 11:17 pm
[quote="stoneyboy"]rose,
end[/quote]
thanks stonyboy for your advice
swidders
by swidders » Thu Jan 15, 2009 12:23 am
you also need to ensure that you buy the right code lead for it to last long enough.
rose
by rose » Thu Jan 15, 2009 9:37 pm
[quote="swidders"]you also need to ensure that you buy the right code lead for it to last long enough.[/quote]
by way of the right code....what does this mean?
swidders
by swidders » Sun Jan 18, 2009 12:02 am
lead is coded according to its thickness. if you put the wrong type of lead down, then you are either going to pay more than is needed or have a job than hasn't the life expectancy desired.
search for the lead sheet association website - they have details of what sort of lead to use where.
rose
by rose » Sun Jan 18, 2009 8:33 pm
[quote="swidders"]lead is coded according to its thickness. if you put the wrong type of lead down, then you are either going to pay more than is needed or have a job than hasn't the life expectancy desired.
search for the lead sheet association website - they have details of what sort of lead to use where.[/quote]
thanks for alll your advice
TheDoctor5
by TheDoctor5 » Wed Jan 28, 2009 10:18 am
It is currently Sun Jun 30, 2024 9:37 pm
