new extension and cavity trays
alandyman
by alandyman » Thu Jan 08, 2009 4:16 pm
I'm planning to put a garage and porch extension on my house.
I understand I'll have to install cavity trays in the existing wall (1960s semi) above the roofline for the porch because the wall will change from being external to internal. (I do need to do this don't I?)
So I also need to do this above the roofline for the garage?
I'm keen to avoid doing this on the whole lot if possible as it'll be a lot of hard work!.
I've attached a picture of the project below.
http://img184.imageshack.us/my.php?imag ... rance01ap2
by stoneyboy » Thu Jan 08, 2009 8:28 pm
alandyman,
In an ideal world you should install cavity trays but as you say it is a lot of work. You could just fit lead flashing above the roof and see how bad water ingress is. If the amount of water entering is unacceptable treat the wall above the extension roof with a silicone liquid - this will need re-doing every couple of years
the specialist
by the specialist » Fri Jan 09, 2009 2:35 pm
Well said stoneyboy - however if you use a resin based waterproofer it will last 10 years!
Aidan
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 10:09 am
If you are looking for general advice on cavity trays and the like, please see our cavity wall DIY how to pages which has useful info on insulation of cavities, cavity trays and lintels and pumped cavity walls.
It is currently Mon Dec 23, 2024 9:37 am
