bidet taps
skinnerlorna
bidet taps
by skinnerlorna » Fri Jan 09, 2009 1:46 pm
Can you use a sink tap for a bidet? If not why? Thanks for help in anticipation Lornask
plumbbob
by plumbbob » Sat Jan 10, 2009 11:00 pm
No reason as far as I know from a regulation point of view, but with bidet taps, the outlet is at a different angle which may make ordinary taps difficult to use.
swidders
by swidders » Sat Jan 10, 2009 11:47 pm
Yes
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:29 pm
It is currently Thu Feb 06, 2025 7:30 pm
