Can I shave a hump in a concrete floor slab?
D-Mac
by D-Mac » Mon Jan 12, 2009 10:04 am
Hello,
I've just laid a floor slab but have found that there is a large hump in one area that is about 20mm above the level that it should be. As I am laying insulation and screed over the top and the screed will have to match the level in an adjacent room, I need to remove the hump to ensure that I have a sufficient thickness to the screed.
Is there a mechanical way of removing this hump? (The concrete is only a couple of days old).
by stoneyboy » Mon Jan 12, 2009 10:59 pm
D-Mac,
Hard way - club hammer and bolster
Easy way - floor grinder - it'll cost you.
D-Mac
by D-Mac » Wed Jan 14, 2009 9:35 am
Thanks. I found the floor grinder on the HSS Hire website. You're not kidding about the cost - £70ish! But it has to be done. I can't think of any other way of sorting out this problem (I'm not going down the bolster route).
TheDoctor5
by TheDoctor5 » Fri Jan 30, 2009 9:03 am
It is currently Wed Dec 11, 2024 9:11 pm
