TWO RADIATORS OFF SAME FEED
6 posts   •   Page 1 of 1
major
by major » Mon Jan 12, 2009 8:19 pm
CAN I CONNECT TWO RADIATORS TOGETHER BY CONNECTING THE SECOND RAD INTO THE 1ST RAD THANK YOU FOR YOUR TIME
C23kW
by C23kW » Tue Jan 13, 2009 1:44 pm
i suppose you could but in my opinin, you wouldnt get very good performance from them bcos ther'll b two rads running from same pipework. It would b farely easy jst to extend the pipework.
by htg engineer » Tue Jan 13, 2009 4:57 pm
Size of pipes ? if smaller than 15mm - NO.
If 15mm then it'll work but would be better having 2 x flow and 2 x return.
htg
major
thank you very much
by major » Tue Jan 13, 2009 6:24 pm
[quote="C23kW"]i suppose you could but in my opinin, you wouldnt get very good performance from them bcos ther'll b two rads running from same pipework. It would b farely easy jst to extend the pipework.[/quote]
major
8mm microbore so I guess the answer is no. thank you
by major » Tue Jan 13, 2009 6:26 pm
[quote="htg engineer"]Size of pipes ? if smaller than 15mm - NO.
htg[/quote]
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:35 pm
It is currently Fri Nov 22, 2024 9:17 pm
