Replacing a PIR lamp - connectors don't match
Peterc
by Peterc » Wed May 16, 2007 1:12 pm
I'm replacing a failed PIR lamp. This has an internal switch to switch the lam on continuously. When I removed the old lamp fitting I found it had four wires, E, N, L and a red sleeved yellow cable. The new fitting only has three cable sockeds (conventionally marked) E, N and L. How do I, or should I connect these?
Thanks for your help,
Peter
by sparx » Wed May 16, 2007 5:57 pm
Hi Peter
It sems like your old set up used an overide switch to put the light on manually, which would be the sleeved yellow 'switch line' & the red was the permanent live, if so then put the yellow into a small connector in fitting term. box (if room) or if you can disconnect it at the overide switch,
regards SPARX
Peterc
by Peterc » Wed May 16, 2007 6:49 pm
Hi Sparx
Thanks for your prompt response - that makes sense I'll give that a go.
Kind regards,
Peter
It is currently Thu Dec 12, 2024 4:54 pm
