rough plaster
7 posts   •   Page 1 of 1
kismet
rough plaster
by kismet » Thu Jan 15, 2009 8:52 am
I have just moved to france and have a few walls that need to be plastered, I would like to do them so they have a slightly rough finish as the house is not new enough to have completly smooth walls. how do I rough plaster?
kbrownie
by kbrownie » Thu Jan 15, 2009 9:47 pm
Depends on what you mean by rough?
kismet
rough plaster
by kismet » Fri Jan 16, 2009 11:45 am
it just means that any kind of plastering I attempt doesn't need to be perfect, I'm not looking for totaly smooth walls. I haven't done any kind of plastering, but as this is very expensive to have done in France, I thought I would try it, and if I can get a rough look (as in textured) it would fit into the rest of the house nicely. if you could recommend a book or a dvd which I could follow that would be good. they don't do classes here as it's a registered profession. thanks
trowel09
Re: rough plaster
by trowel09 » Fri Jan 16, 2009 5:01 pm
[quote="kismet"]I have just moved to france and have a few walls that need to be plastered, I would like to do them so they have a slightly rough finish as the house is not new enough to have completly smooth walls. how do I rough plaster?[/quote] you could add some silica sand to the plaster as you mix,test a small area first,or try to match exsisting roughness with more course sand they come in diff grade god luck
kbrownie
by kbrownie » Sat Jan 17, 2009 7:02 pm
Try
Repair and Renovate: Masonry and Plastering (Repair & renovate) (Paperback)
by Mike Lawrence
KB
swidders
by swidders » Mon Jan 19, 2009 1:05 am
you could use plastering sand / cement mix and a wooden float to finish it off.
not easy but you'll have longer to play with it before it becomes unworkable.
TheDoctor5
by TheDoctor5 » Tue Jan 27, 2009 2:22 pm
It is currently Sun Nov 24, 2024 9:33 am
