Advice needed on building up ground floor level
Ask questions and find answers on a range of subjects relating to self build projects
graemer57
by graemer57 » Thu Jan 15, 2009 10:43 am
Am building a 6m x 7m two storey extension on back of house (living room downstairs, bedroom upstairs).
Originally we were planning to put wet underfloor heating in the living room but have now decided against this on grounds of cost and practicality - doesnt fit our busy lifestyle, so have now opted for radiators and woodburning stove for more instant heat without having to run all the time... please no arguements in favour of UFH, already have the stove :-)
As a consequence we now want to make up the approx 150mm floor depth that would have been taken up by the insulation and screed. We thought of putting 125mm Jabfloor, vapour barrier, 22mm T&G chipboard over the concrete slab and having a floating floor but there is a chance we might move a very heavy piano into this room later and am concerned that the floor will 'flex', Now have decided to fix battens to slab at 600mm centres (cut down to right height from 50mm x 150 treated timber) with full depth insulation tight between and 22mm glued T&G chipboard over and screwed to battens.
Need advice in two areas
- is it ok to put vapour layer under the battens then build away from there? Some advice seems to suggest it should be immediately below the T&G but then it would be pierced by screws
- any suggestions on how to fix battens to slab, or will they be held tight enough by the 125mm Jabfloor wedged between them. I've seen various batten supports that sit on the slab and can be adjusted with shims to take out any inconsistencies in slab levels but they seem either v expensive or hard to get a price on
Any advice gratefully received! Graeme
TheDoctor4
by TheDoctor4 » Thu Jan 15, 2009 5:18 pm
Last year 64% of the questions asked in our forum were answered within our DIY project pages at https://www.diydoctor.org.uk/projects.htm . The project pages are now separated alphabetically and your answers are accompanied by diagrams and the ability to see, and buy, the tools and/or required to complete your project. Use our search box to look for your answer and save a great deal of time and money!
the specialist
by the specialist » Thu Jan 15, 2009 7:58 pm
I think I would probably put kingspan insulation and screed over. The floor will be solid and still warm. I'm assuming you have a dpm under the slab?
graemer57
by graemer57 » Fri Jan 16, 2009 8:53 am
Yes have DPM under the slab Was trying to avoid screeding due to cost and fact that have a lot of the materials already (Jabfloor 70, chipboard and battens). Was only me getting 'cold feet' about the possibility of floor sagging a bit under the point weight of the 3 legs on a grand piano that as stopped me putting a plain insulation/vapour/ chipboard floating floor down and considered supporting the floor on 50 x 125mm battens with insulation between
It is currently Thu Nov 28, 2024 3:49 am
