Our 15yr old boiler has packed up and I am getting quotes for a new Valliant and Worster Bosch. The pipe work coming out of the gas meter downstairs is 22mm but it looks as though is it only 15mm by the time it reaches the boiler(upstairs, 6m over). I have only been able to trace it upstairs part way where it is still 22mm but not too close to boiler.
The issue is that different people quoting have said different things about this pipe.
One fitter said if fitting a valliant i don't need to get the pipes changed but i would for the Worcester(due to connectors they have) and as the wider pipe goes through much of the house it would be fine to leave- just slightly lower efficency. The other fitters have said it MUST all be 22mm to do by the book. Typically the cheapest was the one that didn't think the alterations need doing.
I'm so confused- please help!
