Why does 6kw sauna heater blow rcd
pstevdata
by pstevdata » Thu Jan 15, 2009 3:00 pm
I have just had an electrician fit a new consumer unit for me. This has a RCD and 32 amp fuse.
I have wired a 6kw sauna heater in to this and the heater unit comes on for about a couple of minutes and then the rcd trips out.
If left for a few minutes you can repeat the process but the heater will not stay on
Can anyone offer any suggestions.
Phil
TheDoctor4
by TheDoctor4 » Thu Jan 15, 2009 5:20 pm
Last year 64% of the questions asked in our forum were answered within our DIY project pages at www.diydoctor.org.uk/projects.htm. The project pages are now separated alphabetically and your answers are accompanied by diagrams and the ability to see, and buy, the tools and/or required to complete your project. Use our search box to look for your answer and save a great deal of time and money!
by sparx » Thu Jan 15, 2009 6:31 pm
Hi, if the heater has not been used before or for a long time, the elements which are hygroscopic will have become damp so causing the earth leakage problem.
A good electrician should know ways around this, such as wiring heater temporarily via a none RCD supply and leaving on for some time to drive moisture out.
There are other ways which should only be done under strictly controlled conditions which I will not go into on public forum as they are potentially dangerous in wrong hands but which will work.
Gonna have to get your part-p leckie back to help i'm afraid,
regards SPARX
pstevdata
by pstevdata » Fri Jan 16, 2009 9:04 am
Thanks for the quick reply SPARX
I had read about the damp in the elements somewhere else on web. That is why I had persevered with turning on and leaving for a few minutes, but it doesn't appear to be generating enough heat to dry these out.
As you suggest they probably need to be dried throughly.
Really appreciate your advice.
It is currently Fri Jan 31, 2025 11:44 pm
