Laying laminate around 16" diameter posts
prsutton
by prsutton » Wed May 16, 2007 3:18 pm
How, or with what, do I cover the expansion gap around metal posts? With 1" radiater pipes its easy using click together fittings, but with such a large circumference pipe i can't find anything that I can lay around the pipes. Any ideas??? Help!
thedoctor
by thedoctor » Wed May 16, 2007 8:07 pm
Sealant. You just have to keep the cuts neat. You can also use the project we have on angles used in carpentry to cut beading into small sections and mitre them together to go round the pipes. See project links above
It is currently Sun Jan 05, 2025 4:53 am
