Shower mixer tap problem
umvert
by umvert » Thu Jan 15, 2009 9:40 pm
Ok - first post, so be gentle
I have fitted a standard shower mixer tap with a pull down piece in the middle that makes the shower work rather than the taps.
Problem is that although it works, its not coming out the shower very fast and some water is still coming out of the tap
Can i fix this, i did buy the taps second hand as money is a bit tight
Would appreciate some help
bobplum
by bobplum » Fri Jan 16, 2009 2:38 pm
hi umvert
"you only get what you pay for"sprang to mind straight away
being second hand i doubt there is a lot you can do perhaps some wd40 on the pull device, this is how these taps go after a while and how old is old? im sorry i feel you may after to live with it
bob
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 1:43 pm
It is currently Thu Jan 30, 2025 11:56 pm
