Underfloor heating and slate
chazzyboy
by chazzyboy » Thu Jan 15, 2009 9:44 pm
Hi, planning to lay natural slate tiles onto a concrete base floor with electrical underfloor heating.
Whats the best way to set the heating cable in ? I previously just bedded it into the adhesive and simply laid tiles directly on with no issue, apart from it being awkward and messy ! Is this an ok method ?
The instructions for the heating cable tell you to set it into morter, would you need to add something to this to give it some flex, or does this only apply to the adhesive ? Does it matter if the morter is just thick enough to cover the heating cables ?
I really want to keep the height of the floor to a minimum, so it matches up with other floorings in different rooms.
Advice much appreciated....
by stoneyboy » Sat Jan 17, 2009 9:28 pm
chazzyboy,
Bed the cable in the adhesive as you have done before. If you try bedding in a concrete layer and then tiling, the concrete layer is unlikely to remain bonded to the existing concrete floor.
chazzyboy
by chazzyboy » Sun Jan 18, 2009 9:40 pm
Stoneboy, thanks for the reply. It does seem the easiest way, and keeps the height to a minimum, cheers.
TheDoctor5
by TheDoctor5 » Mon Jan 26, 2009 10:20 am
It is currently Fri Nov 22, 2024 9:27 am
