header tank problems
8 posts   •   Page 1 of 1
manny111
by manny111 » Sat Jan 17, 2009 11:36 am
Hi, I'm a newbie to the forum and need help please. I have a heating system that is run by oil central heating and when not using the oil I use the a warrior multi-fuel stove which takes over the central heating. The problem I have is that when I use the oil for heat, everything seems to be ok but, when I use the stove the heat does not seem to reach all the radiators equally and the water in the header tank gets hot. I have tried to balance the radiators as best I can but the problem with the header tank confuses me. Please help.
aceone
by aceone » Sat Jan 17, 2009 11:54 am
hi ...have u got two seperate pumps....if so could be a pump problem
manny111
by manny111 » Sat Jan 17, 2009 2:01 pm
no, just the one pump,
aceone
by aceone » Sun Jan 18, 2009 7:45 pm
it seems to be overpumping,try reducing pump speed
manny111
by manny111 » Mon Jan 19, 2009 5:29 pm
have tried doing this but then the heat does not reach the last radiator. I've tried balancing them again, but can you tell me when balancing the radiators will it make a difference doing them when the oil is on as opposed to the stove, if so which is the best one to balance them with?
thanks.
plumbbob
by plumbbob » Mon Jan 19, 2009 11:59 pm
Do you change anything when switching over from one fuel to another? The fact that the system can over pump suggests it is not designed correctly.
Balance the system when it needs it. Problem is it may make the over pumping worse. What speed setting is the pump on normally?
manny111
by manny111 » Tue Jan 20, 2009 3:03 pm
the speed of the pump is set at medium, we've tried it at the other speeds, it makes no difference.
TheDoctor5
by TheDoctor5 » Thu Jan 29, 2009 2:15 pm
It is currently Tue Nov 26, 2024 2:26 am
