System needs flushing
6 posts   •   Page 1 of 1
Kully
by Kully » Sat Jan 17, 2009 4:23 pm
I have been told that my system needs to be flushed out, i have drained the system down and tried to add a cleaning solution to a radiator (downstairs) via the bleed screw (very very small hole) but it does not want to take it in.
Also i have two tanks in my loft a large cold water one and next to it a small one with hot water in it, can i add the cleaning solution to the small tank?? when drained off a again can i then add inhibitor to the same tank??
Please help!!
by stoneyboy » Sat Jan 17, 2009 9:48 pm
Kully,
Yes you can add the cleansing liquid to the smaller of the two tanks BUT the small tank should not be hot - this needs investigating.
swidders
by swidders » Sat Jan 17, 2009 10:48 pm
Yes - small header tank is where you put it. Search for Fernox website - it will give details of flushing and protecting your system.
Skids
by Skids » Sat Jan 17, 2009 11:34 pm
Hi Kully
It helps if you remove the whole plug not just the air vent screw, remember you can only add the volume of the Rad this way!
yes in deed, NOT the Big tank ! ! !
hold up the ball cock valve which fills the F & E tank (small one)to stop the water entering the system,
drain some of the CH fluid from a drain valve at the bottom of a Rad, close the valve!
add the cleaning solution to the F&E Tank, ensuring in goes down into the CH system, if necessary top the F&E up
run the CH system for a week (read instructions on CF)
then do it all again with the inhibitor
Regards
Skids
Steve the gas
by Steve the gas » Sun Jan 18, 2009 7:34 am
Yes add to small tank when drained down, but clean tank first.
Hth
Kully
by Kully » Mon Jan 19, 2009 1:50 pm
Thanks folks!!
